neil1967
My AH6000 autopilot has given up the ghost and I intend to replace the control unit etc and retain the Raymarine Type 2S linear drive. The current set up does not have a rudder position sensor, but worked fine. I am told that the linear Raymarine and Garmin/Jeffa drives are more or less interchangeable. The Garmin website says that to use the Garmin GHP Reactor autopilot with a Garmin linear drive does not require a rudder position sensor, but if a third party drive is used, then a rudder position sensor is needed. Anyone have any experience of this? Is a sensor actually needed when using a Raymarine linear drive with a Garmin autopilot, or are Garmin just covering themselves in case there are some drives that are otherwise incompatible?
Neil
Neil
