Refueler
Middle last year - I had the starter motor revamped ... turned key and nothing.
We found that the solenoid was duff and not engaging the starter.
Replaced solenoid - then we had starter cog not always meshing with ring gear ... starter away for checks ... rebuilt with new cog etc ... refitted ... all fine for a few days - then again I could turn key 5x and 2 or 3x out of those would be just a grating sound as starter was not meshing properly.
For the last week or so of use and other day when I started engine to run Anti-freeze through the system ... when engine did not start - I would turn off key - but starter would still be energised ... only way to stop it - was to shut off batterys main switches.
Before anyone asks ... the boat has two 80A/hr identical batterys. Each has the neg terminals common to the engine block / instrument panel.
Each battery +pos goes to a separate single action HD switch .... but I am suspicious that the batterys +pos also go to the starter - using the solenoid as the 'switch' - such that my turning key causes the switch to close as its intended ... turning key OFF appears to not make solenoid open the circuit as it should.
Thoughts ???
My idea is to go ahead and buy a complete new starter with solenoid .... thinking that maybe repairs were not as successful as expected.
Thoughts ???
