Nick_H
Re: Anchoring(Have\'nt Got a Clue)
Sounds easy doesn't it, unfortunately though as you enter a busy anchorage in a bit of a breeze its almost impossible to work out where everyone's anchor is, often the boat will be pointing at 90 degrees to the lie of its anchor, and sailing boats are usually pointing in a different direction to motorboats. You have to watch how the boats swing for a while but its still a bit of a guess.
Invariably at first you will not go upwind/tide enough before dropping anchor, and will find yourself too close to the boat behind when you let out your chain, you may need to be level or even ahead of the boat in front when you drop anchor. Don't be embarrassed to up anchor and try again if you're swinging too close to another boat.
Finally, the 3x min, 5x overnight "rule of thumb" is handy 'cos its simple, but it really is just a rule of thumb. You want a longer multiple if conditions are bad, holding is poor, water is shallow or your ground tackle is a bit light. Conversely you need a lower multiple if conditions are settled, holding is good, the water is deep or you have heavy anchor and chain.
