Talbot
I have a 32ft light weight 1 class design boat. A couple of months back i was anchor next to another. I have 15mts of 7mm chain to 12mm polyester 8 braid (Octiplait to you northern types). The other had 9mts of 10mm and 14mm laid nylon. These boats would rate in the all time top 3 for sailing at anchor. My ride was noticeably smoother. The longer chain even though smaller and smaller stretcher rope just was having a ball, loving every minute of it. He just was too oversized.
Crucial info that you left out was depth of water.
Not surprised that he was sailing around on only 9m of chain. I have a cat and I suspect most cats sail around better than any mono, unless they have a bridle rigged. I definitely noticed a vast improvement/reduction in the yaw at anchor by using the heavier chain.
You comment on tuning the rig to the boat. I would suggest that you not only optimise to the boat, but also to the normally expeced range of anchoring depth, and to the method of hoisting the anchor.
