noelex
An anchor directly connected to the boat, without any chain on the seabed, is almost guaranteed to move;
Someone needs to explain this to the anchors. They often don't understand
Someone needs to explain this to the anchors. They often don't understand.
That's a very posh chain you have there nolex![]()
Sadly it is not my anchor. I shudder to think what the stainless chain and Ultra anchor is worth.
When I dive maybe I should take bolt cutters instead of a camera![]()
5 to one works fine day to day and it's what I tend to go for in shallower water , it just doesn't reflect what's actually happening with the catinery. Check the graph out, it mirrors the catinery equation well even down to shallow depths, bearing in mind it's showing the scope which would just lift the last link of an10mm chain with 230kg horizontal load, not what might make more sense in the real world. And for 30m that's a scope of 2.74:1.Using a formula that adds a constant to the calculation is going to give odd results at the extremes and that formula doesn't deal well with what happens to the catenary in more extreme conditions.
For example, if one anchors in water 2 M deep then add 1 M for the distance bow roller to the water by my formula one would need only 15 M of chain for a 5/1 scope. By your formula if adding the 1 M for the bow/water distance (which should be done to get the correct effective water depth) one would put out 29 M of chain, a scope of almost 10/1 which is I think is excessive and in a crowded harbor impractical.
If anchoring in 30 M by my method one would put out 155 M of chain, by your method 87. 87 M would be a scope of 2.6/1. That would be sufficient in mild to moderate conditions but if it comes a blow the catenary will decrease dramatically leaving the effective angle of pull on the anchor too acute.
Since my past cruising was primarily in the Bahamas and Caribbean where tides are minimal and depths usually moderate I generally adhered fairly close to the X5 formula but like any formula or rule of thumb it should be used with consideration of the specific situation and conditions. For example, if anchoring in deeper waters I would tend to a lower multiplier unless conditions became extreme and of course in any depth with strong winds would add a bit more scope.
Edit. This site has it coming out at about just over 90m chain in your example, 31m to bow roller.
http://www.spaceagecontrol.com/calccabm.htm?F=2300&a=167&q=2&g=9.81&Submit+Button=Calculate
The chain and the spine of the anchor are not in a straight line. I suspect there is no real tension in that setup.
Absolutely! It's Photoshopped....!
No-one, but no-one, actually uses a shiny stainless steel anchor with some shiny stainless chain to deploy it into a dirty seabed.
Everyone knows such 'bling' is only for show, along the marina pontoons, and mustn't be abraded by any suggestion of actual use in a manky marine milieu....
And the chain appears to have a reverse catenary!
Here is a shot of the same anchor from the side:
Anchoring is a fascinating thing to watch. I'd be interested to know if there is a con ensues amongst UK yachties as to the best method of anchoring. Briefly I line the boat up into wind, go astern slowly and try to lay out the appropriate amount of cable/chain until (usually) the anchor bites and the boat stops. If I suspect soft mud I'll wait a few moments for the anchor to sink into the mud before going astern to bed it in tight. This usually works with my delta and I do this if mooring stern to Greek style.
That said I watch numerous Italians, French, Spanish etc. here in the Med dropping their anchors while going ahead thus driving over the cable, then letting the boat drift back with the wind often sideways until they 'feel" the anchor must be OK. I wonder is this how they are taught in the Med?
With a SAILING boat, the latter approach makes a lot of sense.
When anchoring under sail, you should approach downwind at moderate speed. The anchor and warp will then be orientated in the correct direction, the boat will swing round to the wind when the anchor bites.
That's what I generally do - I call it the "handbrake turn" method of anchoring.
100m ...... how much chain were you carrying on that ship?
Richard
I'm glad someone else is keeping the skills of 'cruising under sail' alive. Too much reliance on engines these days............fnaa, fnaaThat's what I generally do - I call it the "handbrake turn" method of anchoring.
