rohanp
New Member
Hi all,
First of many posts I am sure given I've just bought my first sail boat in a Corribee 21!
So, first question is about the anchor rode. The anchor is tied up on deck, connected to a ten metre chain which passes through an anchor chain hawse into a locker in the forepeak of the boat where it is connected to the hull. We also have a 60m anchor warp, but the metal loop at the one end is too large to fit through the hawse.
As I understand it, the only way you could use anchor warp and chain would be to:
1. Go below deck and disconnect anchor chain.
2. Go above deck and pull the chain out on deck
3.. Connect anchor warp to chain
4. Lay anchor
5. Fasten warp to boat
Ideally, I just want to be able to pull out as much of the rode as I need to, first chain and then warp I guess.
Sail mostly around the solent and anchor in depths of 2-4m, so not sure just using the full 10m of chain would be sufficient.
Is there an easier way!?
Thanks in advance,
Rohan
4. Lay anchor
Thanks in advance,
Rohan
