emandvee44
Anchor chain pile up
Exactly what I need, and what I saw on line. I seem to recall that it was expensive (region €500), but I think I can get one made locally for much less.
And on the subject of spurling pipes, this one has two, and two hawse pipes as well (they are the pipes through the hull which the 97mm diam. anchor chains pass through on their way to the windlass [gypsies] and then through the spurling pipes into the chain lockers).
My boat has a hole in the grp deck alongside the windlass - it would be a stretch to call it a 'spurling pipe'
And yes that is a fog bank approaching three days ago off the Portuguese coast, and it is still only 200m vis. Good for the marina - it is almost full with visitors.
Cheers and thanks to all,
Michael.
It does not need to be a road cone which are structurally fairly weak but a stainless steel pole about 1½ inch diameter with a rounded top directly below the hole through the deck head from the gypsy will give a better effect.
The randomness of the chain going into the locker will cause the chain to fall on one side of the S/S pole. As it builds up it will fall further off the centre line until it has gone too far whence it will return and find an easier place to lay.
The Stainless steel pole with a rounded top can be welded to a base plate which is held in place by the weight of the chain in the locker.
Michael.
