Anchor Chain length
kghowe
18 Jun 2001
South Coast
Any advise on anchor chain length? Currently mines 100 mtrs. I think about 1/3 is more appropriate.My cruising area is the solent and this at its deepest is 100ft? But I don't plan to anchor mid needles channel.
So to prevent me dragging about 1/2 ton of chain, on a 35ft boat, in the front locker any reasons why 100ft (remebering 4x rule) shouldn't be acceptable.
Input appreciated
KGH
Dave1258
4 Oct 2003
Yorkshire
www.fantasyflowers-uk.com
If your anchor cable is all-chain, it will hang from the bow in a curve called a "catenary". The chain performs two functions. It exerts a horizontal force on the yacht which resists the force produced by wind and waves, and it absorbs energy when the yacht surges backwards in response to gusts and waves. A completely slack chain it exerts no horizontal force, and hangs vertically from the bow of the yacht, while a bar-taut chain exerts an enormous force. A crucially important state between these extremes is the borderline state, when the last links of the chain are just about to lift from the bottom. The borderline state is the limit for safe anchoring with an all-chain cable. This is because a chain tensioned beyond this point can absorb very little energy even though the tension becomes enormous. Snatching is the physical manifestation of this failure.
The force exerted by a catenary in the borderline state is given to a good approximation by the formula:
Catenary Force in kg = Specific chain weight x (chain length)2/(2 x Depth)
F(catenary) = w x S2/2D (units: kilograms, metres) Formula 1
Force is measured in Kilograms; specific chain weight in Kilograms/metre; Chain length and depth in metres.
When at anchor the catenary force is balanced by the wind force. Thus to understand more fully how one can achieve safe anchoring it is necessary to know about the wind forces experienced by yachts.
WIND FORCES
The main force which is experienced by a yacht at anchor comes from wind resistance. It is proportional to the wind speed squared and to the frontal area presented by the yacht. Broadly speaking the frontal area will be proportional to the square of the length. Experience with our own yacht MYFANWY (a Hustler 35) shows that the cable tension in a wind varies widely over time. But, provided snatching does not occur, the maximum force on the anchor cable is given by the approximate formula:
Maximum force in kg = (yacht length in metres)2 x (wind speed in knots)2/500
F(wind) = L2xV2/500 (units kilograms,metres and knots) Formula 2
Again force is measured in kilograms; wind speed in knots, yacht length in metres.
So with a 10 metre yacht anchored in a 30 knot wind, the maximum force on the anchor cable is expected to be about 180 kg if the chain is not tensioned beyond the borderline state. The force will be much larger if snatching occurs.
CHAIN LENGTH REQUIRED FOR BORDERLINE STATE
For safe anchoring with chain, the wind force should be no larger than the force required to lift the last links of the chain off the bottom at the anchor. Equating the forces given by Formulae 1 and 2 gives the expression:
Chain length = (1/16) x (Yacht length ) x (wind speed ) x Square root of (Depth /specific chain weight)
S = (1/16) x L x V x (D/w) 0.5 Formula 3
Formula 3 can readily be made specific to one's own yacht, since the yacht length, L, and specific chain weight, w, are fixed. Thus, the formula for a 10 metre yacht with 3/8" chain (L = 10 metres, w = 2.0 kg per metre) becomes:
Chain length in metres = (wind speed x [depth/5]0.5
s = v x (D/5)0.5 (units in metres and knots) Formula 3A
If this yacht is anchored in 5 metres of water, the chain length required equals the wind speed. For other depths a correction has to be made according to the square root of the depth. However most yachtsmen will have a preferred depth for anchoring, around which they make only small variations. If for example the preferred depth is 8 metres, the Formula 3A reduces to a still simpler form:
Chain Length = (5/4) x Wind Speed Formula 3B
The factor 5/4 will of course be different for different yachts and preferred depths, but the multiplication factor is readily evaluated. Once this is done, it is easily committed to memory. Of course a scope of FIVE should still be regarded as a safe minimum except under the mildest conditions.
ANCHORING IN SEVERE CONDITIONS
For an all-chain rode, Formula 3 states that the length of chain required for safe anchoring is proportional to the wind speed.Typically one will need a length of chain at least equal to this. Indeed the Formula 3 may well call for more chain than one can deploy. You may not have that amount of chain, or your swinging room may be restricted. But if too little chain is deployed snatching is bound to occur, since the chain will straighten beyond the borderline state: it will lift from the bottom at the anchor, and it will not be able to absorb the energy of the surging yacht. For a well buried anchor, snatching will cause the anchor to "walk" downwind in small steps under the seabed and it is very likely ultimately to pull out due to obstruction or weed. Snatching spells grave danger to a yacht at anchor.
If one cannot let out enough chain to satisfy Formula 3, what is the solution? The first point to note is that a modern anchor will hold even if the cable leaves the anchor at a small angle above the horizontal although this must be less than about 15°. It may not hold to such a high force but it will still hold. To avoid snatching, which would occur with an all-chain rode, an energy absorbing spring must be introduced. The best spring is undoubtedly nylon rope. Experience shows that 10 or 20 metres of nylon Anchorplait, 14 to 20 mm diameter can absorb many times the energy which can be absorbed by chain. But it is still more important now to ensure that the scope exceeds FIVE as ones anchor cable is likely to run straight from the anchor to the bow roller in the stronger gusts.
QUANTITATIVE ANCHORING WITH ANCHORWATCH
The theory of anchoring shows that measurement of the actual tension on the anchor cable by a device such as ANCHORWATCH can give valuable information about the state of the anchor and its cable when it is hidden below the water. Before anchoring, a skipper should make an assessment of the likely wind force from Formula 2, and also calculate from his own version of Formula 3 the amount of chain which he would need for safety. If this proves to be too large due say to limited swinging room or limited availability of chain, then addition of a nylon spring will be necessary to take up the snatching loads which would otherwise be inevitable. Having calculated the anticipated loading, the holding should then be tested up to that level using ANCHORWATCH when one first anchors and the alarm set to some load below the test load. Subsequently ANCHORWATCH monitors the actual load and records the peak load. Clearly if the alarm goes off, the skipper has to take some action. However, if his anchor has been well dug in initially, it may well have held to something higher than the original alarm load: this can readily be checked using the peak load facility. The alarm load can then be reset to a higher value.
So the answer to anchoring in strong winds is:
(1) Before anchoring, make a realistic assessment of the maximum loading you are likely to experience using Formula 2,
(2) Let out the maximum possible length of chain,
(3) If necessary, back this up with at least 10 metres of nylon Anchorplait, 14 to 20 mm diameter,
(4) Make sure that the scope, measured from the stemhead, is at least FIVE,
(5) When anchoring use ANCHORWATCH to test holding to at least the value calculated in (1), above.
(6) Set the ALARM LOAD somewhere below the test load,
(7) Use ANCHORWATCH to monitor the current load and record the peak load thereafter.
(8) If the alarm goes off, you are in danger of dragging and action must be taken.
So yes, 100 ft. will be about right!
<hr width=100% size=1>Someday my ship will come in, and with my luck I'll be at the airport!!<P ID="edit"><FONT SIZE=-1>Edited by Dave1258 on 05/02/2004 20:46 (server time).</FONT></P>
jfm
Jersey/Antibes
Formula 1 is incorrect. It would be correct for working out the catenary force on say a pylon being pulled by the electricity cables. But in this case it overestimates the catenary force becuase it does not allow for the buoyancy of the anchor chain in water which substantially reduces its effective specific weight.
Yes, 100 foot will do fine.
Talon2
24 Dec 2003
Ocean Village
Thanks Dave for that very useful information. I have printed it out, fitted into a waterproof plastic folder and fastened it to the flybridge so that I can read it next time I need to drop the anchor.
<hr width=100% size=1>Keith
<A target="_blank" HREF=http://www.mobiledit.co.uk>http://www.mobiledit.co.uk</A>
DepSol
6 Oct 2001
Guernsey
At least 1.5 times the boat length of chain with rope.
<hr width=100% size=1>Dom
<A target="_blank" HREF=http://www.soltron.co.uk>the website</A>
Dave1258
4 Oct 2003
Yorkshire
Catenary force in kg. based on specific weight of chain/metre 2x depth.
There is no bouyancy in anchor chain it just sinks! /forums/images/icons/laugh.gif
BrendanS
11 Jun 2002
Tesla in Space
Archimedes!
Chain will lose effective weight equal to volume of water it displaces. It's therefore lighter in water than on dry land
<hr width=100% size=1>There is no such thing as "fun for the whole family."
jfm
Jersey/Antibes
No dave, there is buoyancy in anchor chain as there is in any object that displaces water. It "weighs" quite a lot less in water than in air
MainlySteam
24 Jul 2003
I can see that your maturing to the ripeness of 5,000 posts is indeed worthy of worry /forums/images/icons/smile.gif.
Yes, but as the specific gravity of steel is nearly 8, one normally ignores it for normal anchor catenary calcs as it saves the bother of wondering what the volume of the chain is (in any event the loads themselves on the warp from wind, etc are at best estimates), although I assume one could just subtract 1 from 8 and multiply the weight by 7/8, but if so no one bothers.
Nylon is normally assumed to be weightless in water, and the only reason you put an anchor on the end of it is to make one end of it sit on the sea bed - hopefully that means the boat stays in one place too.
John
longjohnsilver
30 May 2001
Almost agree with you Dom, except I've only got 30' of chain and that's always done me just fine, and I anchor where ever I go. A bit of chain and loads of rope, that's what's needed unless youi plan anchoring somewhere really deep and exposed.
BrendanS
11 Jun 2002
Tesla in Space
I've already told you! Go and discover some more epic Cook voyages to trace. Should keep you out of trouble for months....and go have a go at jfm, he's made same response as me /forums/images/icons/laugh.gif
Besides which, just pointing out validity of jfm's point, and not commenting on discussion of catenary calculations about which don't care as just chuck all my chain and rope out (sometimes with anchor on the end if I remember) and it sometimes works, other wise I start the engine again.
AND...reason nylon weightless in water....obviously displaces more than it's own weight of water /forums/images/icons/laugh.gif
hlb
RIP
Any Pub Lancashire or Wales
Christ. We have been here for donkeys years. However did we manage without you!!!!!
<hr width=100% size=1> <font color=blue>No one can force me to come here.<font color=red> I'm a volunteer!!.<font color=blue>
Haydn
