Anchor chain is 50m enough?
Well I can't.
The only way an anchor chain or warp can be straight is when it is weightless (unless it's hanging straight down!)
Well it won't be straight, no. A straight catenary is impossible in the real world. But when conditions get really bad the chain won't be touching the bottom. It will point pretty much at the anchor.
I don't know - I haven't read it. But my experience of life and salesmen suggests the latter :D
Have you tested a modern anchor to experience the difference between that and your CQR?
I suggest you do. In fact if my Twister doesn't sell early in the season, I'll lend you my 10kg Rocna for a while to judge for yourself and perhaps you may just modify some of your feelings against modern anchors and their salesmen. ;)
www.sailingscotty.com
That's a generous offer but what difference might I experience? All I'd be doing is swapping a CQR that works for a Rocna that works.
Exactly.
The question is, is the "science" produced by Rocna valid or simply marketing blurb?
It's valid. Doesn't matter if the chain is tied to an anchor, an island or a very large teacup, if it doesn't drag when you need the catinery most with large forces on the boat it won't be there, the chain will not be touching the bottom but pointing pretty much at the teacup or anchor.
Another site explains it here - http://alain.fraysse.free.fr/sail/rode/static/static.htm
and a some spreadsheets to play around with - http://alain.fraysse.free.fr/sail/rode/synthesis/synt.htm
Thanks for those links. I'll have a good look at them later, but on the face of it they seem to be more comprehensive than the blurb which Rocna is attempting to pass off.
However, the fact that, in the extreme, a chain will lift off the bottom is not in dispute......it's pretty obvious really. What I am querying is the stuff which Rocna is coming out with to explain the obvious, also the follow up waffle and, most importantly the conclusions. Basically they are using mickey mouse science to justify the assertion that we all dump our existing tackle and go out and buy a larger anchor (by which they obviously mean a Rocna). If you then ask them to support their assertions all they do is provide lots of links to their own pseudo science.
It's a bit like asking a Jehovah's witness to prove that the Bible is fact. All he will do is quote the Bible at you!
Why do I get concerned about it? Simply because Rocna are continually using this forum to push their own commercial interests and supporting their arguements with twaddle.
Which is a shame, coz I suspect it's actually a damn fine hook. But I keep looking for reasons not to buy one and choose a competitor instead.
well I think you will find that you are swapping for an anchor that 'works' within a few feet almost every time and that because it's more likely to stay in that position you are likely to have less requirement for all that chain. :)
It's no surprise that Craig should favour Rocna - it would be madness if he didn't - but I find it refreshing that someone from a major manufacturer is prepared to join in a public forum at all - most will not!
Richard
It does 'work' every time - if it didn't I would have got rid of it. And I don't use 'all that chain' unless I need to. In settled conditions I use four times the depth at HW, or 3 times if somewhere very sheltered and confined.
You, and your anchor manufacturer, are offering me a solution to a problem I don't have!
Hardly a major manufacturer. It's Father, son and maybe one or two others.
But they still talk twaddle. Utter twaddle. Most other manufacturers who come on here speak some sense.
I must admit that I also find the way they berate their competitors completely out of order.
You're more charitable than I am. I suspect that it is an OK anchor but there is no way I would buy one. I don't like the way they do business.
In any event my Danforth is fine. It has never let me down
I carry 100m of 10mm chain, and with 60kts of wind forecast for tomorrow night, holding around here a bit iffy, will be using every centimeter of it!
Err, well, despite the total lack of interest, I thought you might be curious.
We held fine - wind now down to 25kts. Anchoring in 10m (at high tide) on gravel, the chain was split into two 50m lengths set approx 30deg apart, one with a 45lb CQR on the end and the other a sort of vaguely 60lb CQR lookalike.
A yacht nearby dragged - I didn't ask if they had a Rocna.
Err, well, despite the total lack of interest, I thought you might be curious..
:o:o:o
Pure luck of course. And all that heavy metalwork hanging of your bow.
If you had a 10lb Rocna and 3 metres of chain you would have been just as well off. They'll shortly be back with the figures to prove it. :confused:
What were the gusts reaching?
