Frogmogman
Interesting start to the Americas Cup today. The two teams look well balanced. It should be an intriguing contest.
But the impressive thing in the last race was that TNZ sailed away from LR in conditions that were probably the lightest we have seen when you would have expected LR to have an advantageI think the forecast is for light winds for the next day or two, but then we get more breeze, so come Sunday/Monday, things could change.
A bit of a shame that there have been no passes so the race is effectively decided by 1 min after the start.
Absolutely. Smaller foils = less drag. Even thought the Italians lost by over a minute, they actually sailed a lot less distance. When the wind picks up, the high/slow mode won't help them at all, and I predict that the Kiwis will drive rings around them.But the impressive thing in the last race was that TNZ sailed away from LR in conditions that were probably the lightest we have seen when you would have expected LR to have an advantage
That isn't inherently trueAbsolutely. Smaller foils = less drag.
Go on then. Tell me how their smaller foils don't produce less drag.That isn't inherently true
High drag aircraft:Go on then. Tell me how their smaller foils don't produce less drag.
I do apologise. I thought I was talking about the difference between the foils on the two AC75 contenders.High drag aircraft:
Low drag aircraft of similar weight:
Basially, drag in wings and foils arises in three way. There is skin friction (or viscous) drag which matters at low speeds much more than high speeds, there is pressure (or profile) drag from the pressure distribution and there is induced drag which is much more complicated but basically arises from the production of lift by a vortex around the wing.
The longer the wing the smaller that vortex needs to be and so the smaller the induced drag. In general the longer and thinner you make a wing the better its lift to drag ratio is.
Aerofoil shmaerofoil, hydrofoil shmydrofoil. They work in exactly the same way. That's why racing yacht keels tend to look like this:I do apologise. I thought I was talking about the difference between the foils on the two AC75 contenders.
Pedants? Haven't seen any around. I'm just someone who teaches fluid dynamics for a living.deleted. Can't be arsed to argue with pedants.
You keep yer clever for the classroom. This is t'internet, where having once done a two-week charter in Corfu carriers far greater weight than all your book learnin'.Pedants? Haven't seen any around. I'm just someone who teaches fluid dynamics for a living.
