robmcg
Last year we changed the prop and the shaft on the boat. We retained the Ambassador Rope stripper from the old shaft. Now we get an excessive clicking noise from the stripper as it hits the striker plate. This is far more pronounced than with the previous shaft/prop and is audible above the engine. In fact, if you rev the engine to cruising revs, the noise is unbearable and sounds like the whole drivetrain is rattling itself off. Boat is currently ashore and the rope stripper is properly secured to the shaft. Any thoughts on why the noise level is now so bad? Is it easier to just switch to a single piece shaft knife or is there something that can be adjusted on the stripper to minimise the noise it makes against the striker plate? All thoughts most welcome
