Aluminium oxide
Sans Bateau
19 Jan 2004
How do I neutralise aluminium oxide prior to repainting? I cant use Kurust, can I?
VicS
13 Jul 2002
You dont say what you are painting but if possible the best solution is to remove all the oxide by grit blasting with a soft grit then etch prime.
Sans Bateau
19 Jan 2004
Thanks guys, it is a cast aluminium radar scanner bracket. A lot of the oxidization I have been able to remove with a wire wheel, but as you may expect some of the corrosion on the inside of the arms is proving difficult to get to.
On another thread someone mentioned Primcon as a primmer for aluminium, any views on that?
oldmonsty
8 Nov 2010
Clean off mechanically as best you can, clean down with warm soapy water, possibly lightly scrubbing, rinse and allow to dry and then you must use an etch primer
Cymrogwyllt
30 Dec 2010
Aluninium oxidises in a matter of seconds after removing the oxide layer. It was a common demo for us. Clean the oxide layer off with acid to reveal shiny, silvery metal and watch the surface turn dull in a few seconds due to oxidation.
VicMallows
25 Nov 2003
Emsworth, Chichester Hbr, UK
I've tackled my cast aluminium hatch twice. The first time I took it down to bare metal as thoroughly as I could; etch primed;Blakes epoxy undercoats; Blakes epoxy top coats. Lasted about 5 years. The second time I thought 'this is a silly (expensive) lark' and simply gave it 3 coats of Hammerite smooth. (or probably the cheaper ScrewFix equivalent). Still good 10 years later.
Vic
Sans Bateau
19 Jan 2004
Vic
It cant be any worse than the original Scanstrut attempt at painting!
macd
25 Jan 2004
Bricks & mortar: Italy. Boat: Aegean
I suspect you're concerned about the furry white deposit on aluminium, which is not aluminium oxide. As cymrogwyllt writes, aluminium forms an oxide instantly in air. This oxide is stable and protective (much like chromium oxide protects stainless steel). Trouble is, in a salt/dissimilar metal environment, it just isn't protective enough.
There was a thread a day or so about Alocrom: www.ybw.com/forums/showthread.php?t=265005.
I've no experience of this stuff but it sounds interesting.
tross
19 Aug 2003
Lymington
The last bit of research I did on this the Land Rover guys used phosphoric acid to clean prep the surface ( after removing the old paint) and then a etch primer.
Ubergeekian
23 Jun 2004
Me: Castle Douglas, SW Scotland. Boats: Kirkcudbri
I was advised to use POR-15 Metal Ready when I dealt with some corrosion on my DS roof (which is aluminium). It seems to have worked fine - well, nothing has reappeared, five years on. It's available from Frost.
From the safety data sheet it's a mixture of Phosphoric Acid, Zinc Phosphate and Octylphenoxy Polyethanol Ethanol Triphenol Methane
