Gixer
Hello,
I'm conscious that I've been asking a lot of questions recently so apologise but promise this will be the last for a while.
When my little 1GM10 (9hp) engine is running and I move my electrical switch to both there is a distinct change in engine note and I guess this is the alternator working harder and therefor putting more strain on the engine. I'm sure I read somewhere that the alternator can cause a drop on HP, or did I make this up?
At the moment I never use the both switch and switch directly from engine to domestic battery so its not really an issue. If I do away with the both switch and add a VSR will the affect on the engine HP like using the both switch all the time? my 1GM is only just powerful enough for the boat and I can't afford to loose any HP
