Alternaters
stamfordian
28 Dec 2001
LINCOLINSHIRE
I have to conect the alternater up on the boat its a standard 75 amp job off a transit looks like Lucas.The three pin conection is no problem 2common for power to battery and 1 warning .However i need to conect it to the tacho ,theres a spade post marked w and a post marked b or 8 not clear ,anybody know which to connect to the tacho???
<A target="_blank" HREF=http://www.arweb.co.uk/argallery/stamfordian>http://www.arweb.co.uk/argallery/stamfordian</A>
tr7v8
30 Nov 2001
Kent
w will be the tacho connection, normally a link to one of the field windings.
Dunno what b or 8 could be, how old is it?
Jim
mtb
30 Jan 2002
cant you connect an avo to see which terminal gives an increase when the rev's are opened up. I know one is for the suppresser ,I'l try find the book which will have the info .
Cheers
Mick
<A target="_blank" HREF=http://homepage.ntlworld.com/boats/>http://homepage.ntlworld.com/boats/</A>
stamfordian
28 Dec 2001
LINCOLINSHIRE
Thanks for the replies had to dash....crimbo shopping urghhhhh
tr7v8
30 Nov 2001
Kent
Mick,
it won't increase in voltage the Tacho measures frequency eg. rotational speed in this case of the alternator. Hence the direct feed from one of the windings.
JIm
