Alluminium anodes with aluminium props
Frontier
11 May 2005
Oxfordshire, England
Are aluminium propellers at risk of corrosion if you use aluminium anodes?
My last zinc anodes didn’t last very long and as I am moored in brackish water I fitted aluminium anodes. I also fitted a galvanic isolator a few months later. Recently I noticed the props have lost most of the black paint and look pretty corroded across their surface. I can’t tell if they have stabilised since changing the anodes or got worse. I did just wonder if having aluminium anodes puts the props at risk. The GI indicator always shows no current so I guess its working. Also all of the pontoons have been rewired recently, so lots of variables that only time will eliminate.
cliff
15 Apr 2004
various
Yep, Magnesium sounds a good deal but they will get eaten away quite quickly.
"Artificial intelligence is no match for natural stupidity"
sailroom <span style="color:red">The place to auction your previously loved boatie bits</span>
Frontier
11 May 2005
I dont think I can use mags, the marina is tidal and when I am out its in the Solent. Just when the lock is closed the marina is fed from marsh land. Ali is supposed to be good for Salt-to-freshish water. But shouldn't the Galvanic Isolator virtually stop all corrosion anyway?
Frontier
11 May 2005
What put me off changing them every six months was the £400 to get her out. However I have since found Sealift2, but that is still about £160 I think. (incl the lift and the anodes) I was hoping the GI would stretch it to 2 years, and if I could get the A/F to last that long that would be good too.
I suppose I am letting the side down on this aspect, as I think all this out of the water stuff is a real pain, a waste of good cruising time and at my marina too ruddy expensive.
D
