rickchart
I have just fitted a NASA AIS radar unit to my boat. Only problem is that you have to use a separate VHF aerial which must be mounted, according to the instructions, a mininum of 2 metres in the horizontal plane away from the radio VHF aerial to avoid interference. Not easy at the top of the mast of a Sadler 29!
I bought a Vitronix stub aerial to use with the VHF and have tested the AIS unit by just hauling the aerial up to the spreaders with the pennant halyard. It works!
I discussed the problem with NASA at the boat show and they admitted that, in their testing, they had merely used the test boat's VHF radio aerial disconnected from the radio and had no practical answer to my query.
It obviously needs to be as high as possible to get the range but need not necessarily be at the top of the mast. In fact a lower effective range of say 16 miles rather than 32 might give less overall information but more useful information on say a channel crossing.
I could mount it one one of the spreaders or on top of my blipper mounting 2/3rds the way up the mast. If the latter I assume that the mast would screen VHF transmissions from the area astern? Would there be any other adverse effects on VHF reception of AIS transmissions if it were to be mounted, say, 1 foot in front of the mast?
Any helpful advice would be appreciated - I can wire most things up but am not an electronic genius!
