Mistroma
I take it that this is all speculation as you didn't put in a link to any rule or regulation.
What you describe is apposite to DSC VHF, nothing to do with the subject under discussion - AIS Tx
As much as some people like DSC, I don't, so even if I were to install a DSC capable VHF, I wouldn't request or program the set with an MMSI #
so to put out an MMSI # on AIS is pointless.
I only suggest putting NO in the AIS MMSI field as a possibility, my personal inclination would be to leave it blank.
I don't think that it is speculation. The ITU Radio Regulations (and US FCC) require vessel owners to obtain an MMSI prior to using Class A or Class B AIS. Class B AIS transponders will not function if an MMSI number has not been programed into the transponder's system.
It is covered in lots of places but following 2 docments should be adequate.
DATA ELEMENTS FOR ELECTRONIC SUBMISSION
MMSI is a mandatory AIS field (Mentioned elsewhere that the format must conform to ITU standards)
http://www.itu.int/ITU-R/terrestrial/docs/mars/AtoN/aton-electronic-notif-en.pdf
OR
M.1371 : Technical characteristics for an automatic identification system using time-division multiple access in the VHF maritime mobile band
https://www.itu.int/dms_pubrec/itu-r/rec/m/R-REC-M.1371-5-201402-I!!PDF-E.pdf
Extract below
3 Identification
For the purpose of identification, the appropriate maritime identities should be used, as defined in Article 19 of the Radio Regulations (RR) and Recommendation ITU-R M.585. Recommendation ITU-R M.1080 should not be applied with respect to the 10th digit (least significant digit). AIS stations should only transmit if an appropriate maritime mobile service identity (MMSI) or unique identifier is programmed.
Sorry, above already covered by others. I obviously forgot to refresh the page before replying and didn't see the other replies.
