AdrianPetts
Just venturing into the world of AIS and was wondering what would be sensible values to enter for CPA and TCPA for a unit on a sailing boat in English channel.
I'd turn the alarm off, its very annoying especially if there are lots of ships. like ch 16.![]()
For two years now I have had to completely suppress the AIS CPA/TCPA alarms in OCPN due to the expansion of Class B transponders in the Adriatic. This is a real disadvantage in waters populated by fast ferries with little respect for leisure craft and against which an alarm was a significant safety feature, with their high closing speeds.Oh yeah, my alarm lives turned off, unless we're on an offshore passage!
I am informed that some manufacturers allow alarm settings based on target speed (Vesper Marine) and I did make the proposal to the OpenCPN developers for a similar function (or better, on Class B targets), which all seemed to go down like a lead balloon.
I first made a 'New Feature Request' for alarm suppression for Class B targets, which didn't even get acknowledged. In retrospect I could understand that it would be a controversial amendment.That's very disappointing. Did they say why they weren't interested?
Then learning of the Vesper Marine alarm filtering on target speed, thought that a good compromise, all those Class B alarms I was getting were mainly sailing yachts well under the sort of Class A speeds that were likely to kill me. So I wrote again to the Cruiser Forum with that proposal. This time I did get a grudging response that the alarm parameters of OCPN was not very extensive ... but nothing more.
A pity really. In every other way an excellent program that fulfils all my requirements.
Before going down to the boat in Spring last year I had downloaded the source files and took them with me on a laptop. Then, while weather-bound in harbour, I did look to see what might be involved - it seemed, to this rusty old software engineer who hasn't looked at any source code for a lifetime or two, rather a trivial change. I made the changes but with only limited on-board PC resources I didn't compile or build so maybe my impression is the result of not understanding the full ramifications.Sounds like they don't want to dedicate the time developing the feature, rather than disagreeing with the idea.
If new to AIS, don't underestimate the value of the bearing and heading readings.
Bearing is like your own, super accurate hand bearing compass. 2 benefits: You are accustomed to making judgements on this data, and also is the information that tells you if the CPA will be ahead or astern of you (if it's a crossing situation)
With heading you can see if the ship has made a small course adjustment. They often adjust a very small amount when quite a few miles from you to just pass behind, the CPS will increase as he does it, but remains small. In this instance though keeping is likely the best solution. The adjustment is so small you wouldn't see it by eye or hand bearing compass.
None of these numbers give you "the answer" in their own right, but certainly can help you make good decisions.
Absolutely. I rarely use my AIS apart from crossing the Channel. I have watched a big ship adjust their course by 5 degrees to go behind me. Using Mark I eyeball I thought that we would be OK BUT would have probably altered course to go behind him without the info from the AIS. My reassurance was not from the fact that the AIS 'said' he was going to miss me but that he had 'seen ' me.
