fireball
As I (and at least one other) said earlier in the thread - VHF range is largely dependant on the height of antenna - the higher they are the greater the horizon - so the thought is that if your mast does unexpectedly reduce in height then you've got the backup antenna - and if it's not getting through then you can either dismount it and raise it (on a boathook?) or whip up a new temporary one - this can be done with a bit of coax cable ...I have the definite back up of a proper VHF transmitting aerial should the need arise to use it, even if it is of limited range?
Around the UK, the coastguard antennas are normally raised so high that their range is massive - hence we can regularly hear Solent CG in Cherbourg but only hear other vessels in the (eastern) Solent when we get back within sight of the IOW.
