sj8070
Active Member
Hi all
We have a problem that we are 99% sure is air getting into fuel as whenever engines are bled they will then run for another 5 mins
have changed all filters, even had one of the fuel pump replaced - still getting the problem
We then assumed must be an issue with the fuel tank - thinking perhaps a layer of gunge (as boat had been stood for a year without use before we bought)
Today we checked the tank (big job as carpets had to be removed, sensor removed etc) and the fuel seemed absolutely fine - see pic below
Absorleyl lost as to what it could be now - both engines connect to the tank with diff hoses so unless both engines/fuel circuits have developed the same issues it must be the tank
Only possibility we can think of is that gunge has collected up by the intakes that we can't see ?
