DangerousPirate
Pot usually refers to a potentiometer or variable resistor. There may be one on the board for setting up during manufacture.
About 10mm square with a screwdriver slot for adjustment.
View attachment 143496 View attachment 143497
If there was smoke you may be able to identify the burnt looking component. The next problem is to read the identity or value as this may be unreadable if it is blackened.
There is a spare board here for a not inconsiderable cost. PCB
This could be the 'pot'
Other people have had to replace the power transistors Repair
I think mine looks different? I'll be with the boat in an hour or so, then I can take pictures.
Yes ?
2 wires onto the tillerpilot motor is all that's needed. Someone with much patience installed it inside
This is what's needed>
IBT_2 motor controller (with the heatsink)
arduido nano (just below heatsink)
raspberry pi zero 1 0r 2 W (on the right)
5v. (from usb hub as it was easy way to do it for testing)
MPU9255 9 doff gyro/compass accelerometer. Not in pic.
2 versions, tinypilot standalone or buil;t in to openplotter. Tinypilot creates hotspot for web page control or opencpn. Not sure android opencpn is working but PC opencpn activate a route & the autopilot will follow.
Will follow a route, gps course, apparent wind or true wind.
Gains & setup available from opencpn .
Wiring is the time consuming bit, software works out of the box & from user reports very likely as good control for steering a boat as you'll get at our level. Author (who wrote many of opencpn plugins & rewrote a lot of opencpn code to speed it up) is working on machine learning & AI for learning as it goes.
That is really unexpected but very welcome. Looks like a fun project and only mildly complex
