After Hellevoitsluis
heerenleed
13 Mar 2002
Netherlands
www.heerenleed.com
Ian,
Are you going to Steenbergen as well?
If I'm still there when you lot get here I'll be happy to give you lots of advice and info. Nicholson 48 Heerenleed. We live aboard so usually there's someone aboard.
If you don't go to Steenbergen just let me know and I'll write things down for you.
Happy sailing
<hr width=100% size=1>Peter a/b SV Heerenleed, Steenbergen, Netherlands
squidge
6 Jul 2002
East coast
Hi ian, i am planning to do a bit of holland in August and wondered if you had found a good pilot book ?/forums/images/icons/smile.gif
ianwright
Home: Peterborough, Mooring, Heybridge Basin
The normal almanac of your choice, Reeds/Macmillan in my case, plus North Sea Passage Pilot and Cruising Guide to the Nederlands will do for a start. The Dutch 1800 series charts and the ANWB guides are a must have.
Where are you going? The Zeeland area, Flushing to Dordrechtis great fun.
IanW.
<hr width=100% size=1>Vertue 203, Patience
kingfisher
7 Nov 2001
Belgium, Holland
www.allejachthavens.nl
http://www.staandemast.nl/html/kaart.htm
Entering at Flushing. First night in Michiel De Ruyterhaven, watch for cross current at springs. Sill at 1.5m depth LLWS (on entering, count number of horizontal beams on lead walls to gate: nine means you have 1m50.
From Michiel de Ruyterhaven, go 5 cables east, and enter the kanaal of Middelburg, which leads to the Veerse meer. If you have little time, go through the Veerse Meer, and get to Goes. Otherwise take it slow: lunch in Middelburg, overnight in Veere.
Have fun at the Zandkreeksluis. The Zandkreeklock in season makes the lock at St-Kats a docile animal. 7 different nationalities trying to ram each other. Hilarious.
The bridge at Goes only opens untill 2000h, and the bridge is three miles from the lock. Do not be tempted to stop in the marina after the lock, but continue to the town. Immidiately after the town bridge, turn to port. You'll find the most picturesque marina, in the middle of a park.
From Goes, Go to Willemstad on the Amer. Again a long haul through Oosterschelde and Volkenrak. Otherwise stop at St-Annaland
AFter that, you're out of my turf, but someone else will help you along, I'd guess.
BTW: another option: Go up the Westerschelde, stop in Terneuzen (my home port), and continue up to Antwerp.
<hr width=100% size=1>Group of people on the pontoon: skipper is the one with the toolbox.
http://sirocco31.tripod.com
