LiftyK
Hi, when I connect my portable solar panel to my service battery, it sometimes causes the shore power unit (not connected to mains at the time) to run its fan. May I ask for your advice:
a) is this causing any harm, apart from losing energy to the fan?
b) how might I prevent the fan running?
The setup
- two 12V Lead acid batteries
- all-in-one shore power and multi stage battery charger for both batteries, Dolphin I think, professionally fitted many years ago
- NASA BM1 battery monitor, fitted by me, only to service battery, following all instructions and works fine
- new portable 120W solar panel with built in PWM charge controller, connected to the load side of the NASA BM1 shunt. The main purpose of the panel is to enable a compressor fridge to run continually while out and about
- the solar panel is only connected when we don't have shore power
What happens
The solar panel is new. Last weekend I had my head in the cockpit locker where the all-in-one shore power and charger is fitted. To my surprise, I could hear the Dolphin cooling fan running even though we were not connected to mains shore power. The solar panel was connected. It was sunny and warm. Later in the day the fan stopped, perhaps related to reduced power coming from the solar panels. Apart from this strange behaviour, the solar panel appears to work fine.
What next
Clearly having the shore power/charger fan running, powered by the solar panel, is not a good setup. What modification would you advise please? I will try to see exactly how the shore power/charger is wired in next time I can get on the boat.
The setup
What happens
What next
