vas
good afternoon,
as per the main rebuilt MiToS thread, I just got in my hands (so to speak) two nice, relatively filthy el.toilets in working order.
Since I'm redesigning the whole space and moving the heads from stbrd to port, I have to redo the lot, create new framework and support for them, wiring, piping, etc.
I will try as per jfm suggestion to rotate the motor assembly so that the inlet and outlet of sea water go vertical compare to the horizontal arrangement they are now and thus improve on the looks by avoiding the seawater supply from being upfront in your face, BUT I also need to do a proper clean/check on them
Not having EVER dismantled such a filthy device, I did a search on the forum, came up with some interesting stories of blocked toilets and how to unblock them, what type of paper to use and not to use, whether one should or shouldn't use a black water tank, etc. Noone bothered to give hands on experience on dismantling and cleaning them though.
I'm not talking about getting a 10mm spanner and turn left to undo the screw I can do spanners alright, I mean more about tips on what to have available beforehand, how to clean them before opening up, what to use to soak the blades (?) or whatever is in the macerator, to avoid the stink and/or getting some form of hepatitis in the process
You get the point.
I do appreciate it's not a supper time project to even think about it let alone find old photos and post them
, but any hints would be much appreciated.
cheers
V.
cheers
V.
