PaulRainbow
I agree with much of what you say, Lithiums make sense for a few, but not for most small yacht/weekend users.From your perspective I can see that - however the way you use your boat is so very different from the majority for all the reasons you seem to ignore. If lithium does indeed become a straight swap (phone call and a undoing a few terminals) then you are right, BUT it is not and never will be for most boats. There is little advantage available to justify the cost of the change. The "last battery you ever buy" only holds water if you keep the boat for ever OR like you have a pattern of usage that means either you will use up LAs quickly or won't be able to consume electricity in the way you can now. Most boats change hands in much less than the lifetime of AGMs so many owners will never have to replace batteries. Same with cars now. The average life of cars is 14 years, but ownership typically 3 years. My wife's car is 19 years old, had it from new and just had its second replacement battery. My stop start C max is 7 years old and still on the original battery. My Morgan battery was changed after 19 years.
Boat batteries like engines die from misuse and neglect and there is no reason why 10 years is the minimum life expectancy which is pretty long term for most weekend type sailors.
As much as your AGM "argument" makes sense for some, it also makes no sense for many others, using the same arguments that you use for your Lithium vs AGM argument.
For many, a couple of £80 - £100 "leisure batteries fulfil their needs.
My Merc battery is the original AGM at 6 years old. Boat SLA's still perfectly OK at 5 years. Who knows when either will dies, but the Merc looks after its own batteries, i have to look after the boat batteries, if i get it wrong, they die early. Equally, if i fit Lithiums and get it wrong, they die early.
