photodog
Lord High Commander of Upper Broughton and Gunthor
thanks so much for your opinions , not sure a dufour 40 7 years old at 108k is value , my options after much research are
2006 jeanneau 39i
2008 beneteau 37
2007 beneteau 40
all well within the 100k budget
opinions welcome
Well, none of those are gonna be in your budget..... and you need to check the loa to get inside 12 meters...I dont think that either of the Bene's are under 12meters...
If you want to stay within 100k you are gonna have to go for a older boat. I would say the SO40.3 is a good bet.... very nice better sailor than the 39i....
And you probably should reappraise what you consider good value... all of the three you are looking at will have a bit of depreciation left in them... dont make the mistake of thinking newer equals better value...
With all three of those boats you will need to be two up most of the time just to handle the boat upwind.... as the mainsheet is on the coachroof.... if you are gonna short hand you should give a bit of thought to the layout of the deck gear..
The Dufour is a better boat in my opinion! And better value, as it has probably bottomed out on its depreciation....
