YupYou don't need a build up anything like the depth of the stringer. Far easier to remove the necessary section of stringer to make the built up section. There will be no loss of stiffness when a built up section is incorporated where the stringer was. The job will be far easier. If you do as Neeves suggests and make up a thick piece of GRP you simpy need to glass it in place with extra layers of cloth. Very strong and rot proof
I see the job is getting bigger as the bad core bits are getting revealed
It looks like OP has pulled out the pad etc already. I would have advocated careful measurement and observation to see exactly what has compressed when the shroud is loaded up.
The core material adds very little to the strength of the stringer. It's really just a former for the GRP wrapped around it. The stringer only adds longitudinal stiffness in most cases. A bit like the difference between a sheet of thin steel and the same sheet turned into corrugated sheets.
Does your remedy allow for the end of the stringer to be bonded to the bulkhead. It is that bond that has probably weakened & allowed the stringer to crush up under the cored deck. It may be that the design was not relying entirely on the deck for strength but a mixture of stringer-stringer/bulkhead joint-deck. All acting as one. Just sticking a pad in & ignoring transferring load to the bulkhead etc may not work. But I may have not understood your description correctlyIn post #18 the OP shows the excavated core. It's a very strange detail to have a balsa cored deck plus a stringer and so close to a bulkhead.
Referred to as “ angle “ ?I like Geem's suggestion -
You can buy stainless off the shelf as 90 degree long strips of various dimension -
Jonathan
I sat wondering what they were called - racked my brainReferred to as “ angle “ ?
Way back a post suggested new chain plates on the cabin sides.
Having seen the deck photo that would be my preferred option. Strong and simple using the cabin side as a beam to spread the load. As this rig attachment has failed the others must be suspected of the same failure waiting to show, so I would replace them all.
The cored roof is the problem, as the core slowly failed under compression allowing water in that speeded up the failure. Hence my saying the others are also suspect, even though they may appear to be sound now. Good practice is for the area with any attachments through deck to have a solid core to prevent the compression problem. Attaching the chainplates to the cabin side will not have that problem. Glassing in a good quality ply pad on the side then bolting through from chainplate, cabin side, backing pad and a plate of similar size to the chainplate to act as washer will give a stronger fixing that is far less likely to fail.The roof is cored, but the sides aren't as far as I'm aware so the extra internal strengthening to put in place to achieve that could be significant.
What about an excavation of balsa core and replacement with glass or ply pad at each of the existing fitting locations in a suitable sized area instead though? It would potentially yield a similar result without the need to fill 12 holes in the saloon roof (which will always be a visile repair) and go again elsewhere on the sides? (plus I have windows and portholes to contend with)Glassing in a good quality ply pad on the side then bolting through from chainplate, cabin side, backing pad and a plate of similar size to the chainplate to act as washer will give a stronger fixing that is far less likely to fail.
I think you are on the right course. Go for itWhat about an excavation of balsa core and replacement with glass or ply pad at each of the existing fitting locations in a suitable sized area instead though? It would potentially yield a similar result without the need to fill 12 holes in the saloon roof (which will always be a visile repair) and go again elsewhere on the sides? (plus I have windows and portholes to contend with)
I would say, this is a motor sailer with a modest sail area, so the stresses involved are a little less arduous than in other situations.
