Advice - filling exterior wood screw holes
nagstevens
New Member
17 Oct 2017
I'm just tidying up a few redundant fittings and before I remove them - leaving small screw holes in the wood - want to see if there's a preferred wood filler out there, with effective protection from water ingress.
why not open up a little bit the hole and glue wooden dowels with epoxy! then sand it , and that would be good looking!
If it's bare/varnished wood you could make your own plugs to match the grain. Not too difficult over say 6mm, a bit fiddly if less that that but still possible. If you're doing a lot you can buy taper plug cutters to use in a drill stand, otherwise it's a simple paring job - but watch your fingers!
Yes thats a nice tool indeed!
Definitely use wood plugs - you can get plug cutters in different sizes, just make sure you get drills to suit, you can get both metric & imperial sizes - like thttps://www.ebay.co.uk/itm/4-x-Wood-Plug-Cutter-Cutting-Woodwork-Power-Tool-Carbon-Steel-Drill-Bit-SetIK/123152336860?hash=item1cac7387dc:g:OroAAOSwn-tZL4T6hese - Other suppliers are available, best used in a pillar drill, make sure you use identical wood, just glue in with a waterproof glue and clean with a chisel after setting.
Don't know how it will turn out, I filled small rivet holes with dowel, glued, knocked in with a punch and epoxy filler over, then trimmed inside with a dremel. Here's hoping...It's the end grain inside which may show.
Get some 6 or 8 mm dowels glue them in then cut/sand flush. I use the same when I've had to do a bit of damage renewing old fixings. The dowel gives something solid to grip into.
Don't use dowels as others have suggested. Wood color will be wrong and you get end grain.
Use a piece of timber of the same type and cut your own bungs using a plug cutter. see below.
Consider using varnish as a glue if you think you might ned to remove them in the future.
That's good advice for plugging over a screw but not very likely when the screw has been removed.
You can stain the dowels before inserting if you're bothered about the colour. I've never had a plug cutter so always use dowels.
