chris-s
We have the same panels, victron and renogy chargers wired the same way (different fusing and with lithiums) and it works great. We dropped in the lithiums, with a little rewiring, when the agm’s gave up using the same basic charger setup, just changed the battery type in the renogy.Coming back to this as I got sidetracked with other projects for a bit.
Following the advice that what I really need is more solar, my current plan is:
Keep my existing 2 x 110Ah AGM domestic batteries for now.
Upgrade the 30W solar panel to this 100w Renogy item, with a pole / tilt mount.
Replace the existing MPPT controller with this Renogy combined MMPT controller and DC-DC charger.
Connect that to the domestic bank, engine battery and solar panel, using 60A mega fuses for the batteries and a 10A inline fuse between the panel and the MPPT controller.
Upgrade my existing Victron mains charger to a 20A IP22 with Bluetooth (I hate the fact I can get zero info from the current one).
Connect that mains charger to the engine battery (with a 80A mega fuse), and rely on the DC-DC charger charging the house bank when there’s not enough sun and the boat’s plugged in.
My thinking is this will allow me to drop in Lithium batteries when my AGM ones wear out.
Can anyone see any major flaw(s) in the plan? All advice gratefully received as always.![]()
What are you going to use to monitor the charge state? You can use the renogy Bluetooth adapter with the phone app or one of their displays. We opted for the one core which allows for remote monitoring.
