Adding a weight to mainsail head to aid dropping.
fredrussell
24 Mar 2015
My main drops very nicely, apart from the last two metres or so. To avoid the faff of going up there to pull last bit of sail down I wondered about attaching a weight to head board. Wouldn’t take much I would have thought - perhaps a kilo or so - not a huge amount in the great scheme of things?
Bonkers idea?
fredrussell
24 Mar 2015
Slides are ptfe’ed up! Sail drops like a good’un - it’s just the last bit. Downhaul line adds complexity- would rather avoid that.
Boathook
5 Oct 2001
Surrey & boat in Dorset.
Bit rude, but hey ho.
If boat is pitching around, any reason to avoid a trip to the mast is a good thing surely? Especially if you’re singlehanded.
If the boat is pitching around the haliard will be also and will keep trying to raise the main a bit. Either accept the last 2 odd metres being up or go to mast and secure which will only take seconds.
johnalison
14 Feb 2007
Essex
I do see your point. My main comes down pretty well but sometimes the last few feet are slow. I too will avoid going to the mast, at least until in sheltered water, and it is a good idea to avoid the windage from the remaining sail as far as possible. I don't have a solution, but I usually find that left alone the last few feet will shake themselves down eventually, and if there is not enough wind to do this it isn't going to matter much.
JimC
30 Aug 2001
Lancashire
Agree about the rudeness. I had the same problem as the OP and solved it by fitting a Tides Marine sail track. Easy to fit and now the sail now drops smoothly straight down all the way. Easy to fit and no extra string etc.
Vdeo here
wingcommander
25 Jul 2013
Not seen the tides marine system close up, however video gives the impression the additional weight of the metal sliders are what causes the easy drop . So may as well add a weight to the existing sail to achieve same results.. I may be wrong though ..
JimC
30 Aug 2001
Lancashire
The sliders are heavier than typical plastic ones but the difference is trivial compared to the weight of the sail which, if the friction was low enough, would be sufficient to bring it all the way down. With the TM slides running in the special plastic track it is low enough. The sail is easier to hoist too and in that case the weight of the slides is working against you, but again it's trivial compared to the reduced friction.
Fr J Hackett
26 Dec 2001
Saou
If you are dropping the main then you are at the point of entering the marina or have picked up your buoy so what is the problem of leaving the last few feet until you are secured if the idea of going forward doesn't appeal.
Yes it's a bonkers idea.
wilkinsonsails
4 Jan 2010
Kent
Probably won’t make a great deal of difference to stiff new sail ,as the spring of the flakes will prevent it from folding well
On the other hand a very tired floppy old one might behave .
The Tides track let’s me drop both main and miz in seconds .Provided we are head to wind the sails fall easily into the Sailcovers
.I don’t have to do anything .It’s wonderful.
.Spend too long sail wrangling at work to have to do it when sailing as well..
thinwater
12 Dec 2013
Deale, MD, USA
sail-delmarva.blogspot.com
Yes - Bonkers idea. :)
If pulling down the last metre or so is a faff, find a new pastime.
Many people try to keep weight away from the top, even middle of the mast.
Jonathan
Stripping halyard covers. Eliminating shackles. Dyneema standing rigging. Carbon masts. High tech fabrics.
It's just some friction, waiting to be eliminated.
