poggy
Hi,
I am in the process of adding a second battery, we currently only have one which does everything and quite often we run it flat. I have bought a 120ah battery for the domestic circuit so it should give us some extra reserves.
I have also bought a new 3 way battery switch to split them. My questions are:
1. Has anybody tried the super flexible battery cable which is available and what diameter should I use. It is a 28' boat with no serious loads on the battery, only lights, bilge pump, diesel heating etc.
2. If you don't fit a split charger will it seriously affect the battery charge states, the engine battery will be 75ah and domstic 120ah. If I do need a split charge does anybody know a good source at a good price. The alternator is a standard Yanmar 1GM10 35amp one.
3. Does anybody know where to get a nice looking switch panel which doesn't look like it came from the science museum. Preferably with a low cost battery indicator.
4. Should I use tinned cable for some of the domestic re-wire to prevent corrosion, again does anybody know a good source.
Sorry it's long post, but I would appreciate any input on the above.
Thanks for your help.
Poggy
Poggy
