dpb
AD41B.....looking grim, views and advice welcome! Update.
A great boating weekend was somewhat marred by some kind of mechanical failure on the way back to the berth. I am really not sure how to proceed on this one and would welcome any views and advice as to best way forward. I will try to be brief.
Engine AD41B
Cruising in at 3000rpm, took her up to maybe 3300 for last mile before harbour entrance, but not WOT.
After less than 30 seconds, unusual noise from the back, nothing dramatic, best described as rumbly clatter no louder than normal engine, just an extra sound.
Temp reading normal
Throttled back and once off the plane realised that the port engine had stopped.
Decided to try nothing until back on berth as not far to go.
Noticed however on the way back that the gear lever on the stopped engine seemed stuck, after a few minutes it would move from neutral to reverse but not forward.
At this point I figured a leg problem.
Once back on berth, checked leg, looked OK (havn’t raised and checked props), under the engine hatch all OK except for coolant in bilge which looks like it came from the filler overflow as it is splattered on the adjacent fresh water tank. Coolant level is low, (topped up that morning).
Gear lever now working normally.
Start the engine, fires straight away and sounds normal, engage forward and reverse gear, all seem working OK, oil pressure fine.
BUT.......smoke coming from crank breather, and the oil filler when removed, quite a lot of smoke. Not black, not really white so I suppose grey. My impression is that it is exhaust?
Tried revving a little in gear a couple of times, didn’t sound quite right but the boat was tied up so didn’t try too hard.
Oil in dipstick and under filler lid looks normal.
So, what next, I shant go through my theories now to keep the post short but they focus on piston / piston ring issue, head gasket or valves (which I adjusted recently). But I don’t get the cause to fit all the symptoms.
So what do you think?? (Me thinks I'll be calling a mechanic real soon!)
Thanks in advance!
Engine AD41B
Temp reading normal
Thanks in advance!
