global_odyssey
I've replaced Alk's aluminium framed 5mm toughened glass windows with custom-made 10mm acrylic ones. This is only because the old frames were so well attached that they were damaged and bent during removal.
The new ones are CNC machined with a 3mm rebate around the inner edge (and 4mm chamfered outer edge), then sanded and annealed to relieve stresses before painting the rebate with a 2-pack acrylic silver paint to simulate a frame - which then hides the 3mm foam gasket seal. They are fitted with A4 Interscrew-type fasteners/M5 pan-heads/washers.
They look great (the acrylic apparently has a 10 year UV guarantee).
... But are they strong enough for serious offshore work?
Are there any "rules" about windows and materials?
