vic008
Need to free alloy-alloy join on furler. Frozen together. Thought make dam with sikaflex And soak with the above. Bearings inside are Torlon. Will acetone attack these.
I use the mixture on cars and it works extremely well - I try to get it working 24 hours before I need the part freed. Recently I've substituted brake and clutch cleaner for acetone and it seems to work just as well, and I feel that the thinning is just to help deliver thick oil before evaporating.
Good as it is, I don't think it's the right stuff for a stuck foil section. I'll repeat that I've read that soaking in Ammonia is supposed to dissolve Alu oxide - don't know, haven't really had the chance to try it, and none of the people that I've suggested it to has ever replied with a yea or nay. Hot water is the most common advice.
Aluminium oxide is amphoteric but I am pretty sure it will not dissolve in ammonia solution. Please let us know if you find that it does
