jon711
I caught up with the racing in the evening afterwork on YT. 5 seconds to the start it goes to a 30 second ad break, when it returns they are halfway up the fist beat!!!! arrrrgggghhhh
Well, if not stopped in 1988, you talk as if the pre 1988 history is more important than the post 1988 history. As if the direction of the cup now is "wrong" because it has changed a bit.
Which simply by definition cannot be true, because at its very core the cup is something that is raced in mutually agreed boats between defender and challenger. If the defender and challenger of record say "this is what we're racing the cup in" then by very definition that IS the cup. Because the deed of gift makes it absolutely clear that if they cannot agree what the cup should be raced in the challenger has the right to say "OK, 90 foot on the waterline, see you in 7 months". Pretending that because you don't like it, because the current boats have deviated in this way, or that way, from what came before, because to you it's not the "real" cup that it somehow isn't the cup, or isn't "true" to you ideal of what the cup should be, isn't, I'm afraid, valid.
The fact that there was a practice for over a century of using an existing class is an interesting historical fact, for sure, but it has no bearing on what is raced in this cup, or the next cup, or the 2145 cup. It was more a product of its time, in the same way that flying boats are a product of this.
The basic truth is that to decide what the next cup will be sailed in you need to win this one. That has always been the case. These days even the challengers are pre-selected as people who will agree with the broad approach the new defender has for the next cup.
It's debatable if that's true during the 12s era, especially post about 1975, but even accepting it I go back to my point which is "That's historically interesting, but so what? What relevance does that have to the cup of today?"What I said was clear - the Cup's format in terms of boat style was not really changeable for most of its history. For most of its history, the Cup was sailed in the fastest existing class of inshore racing monohull. That was constant and therefore NOT really "changeable".
The cup DID periodically change what boat was used. That they chose something that already existed is a product of their era. And especially in the 1958 that adopted the 12s when the cup restarted after a 20 year break. For that cup it was felt that using an existing meter class was a more affordable option than going back to the J's of the last pre-war cups. If they'd operated in the commercial and sporting reality that we do today they'd probably have dreamed themselves up a new class then. Different times, different solutions.
But if you accept that the defender can essentially do what they want, and the cup of today is the cup, then whilst discussing the history of the cup is an endlessly fascinating topic in itself, in the context of a thread about the current cup I confess to being somewhat at a loss to understand what your point is?
Let’s not duplicate here the diversion that was in the previous thread. Perhaps take back there if you want toAs noted earlier in post 35, I was referring to when the 12s were chosen. I could have been more specific but if so that means every post will be longer.
In post 34, you said that ""what the cup is about" could mostly be summed up as "changeable". Therefore;
1- in post 34 you referred to what "The Americas cup has always been". If the Cup's past was relevant "in the context of a thread about the current cup" yesterday then the Cup's past is still relevant today. Nothing significant changed in the past day;
2- If the Cup's past is irrelevant in this thread then perhaps you shouldn't have raised the Cup's past only yesterday;
3- the Cup wasn't really very changeable until the cats came in.
4- To say that the choice of classes that existed "is a product of their era" may or may not be true but is a complicated subject that can only be discussed at length and with reference to historical evidence. Whether that practice should have changed is equally complex and also useless to discuss unless we go to the lengths of obtaining evidence.
Considering that this is just a deviation perhaps we should leave it there.
The fact that Formula 1 teams are heavily involved in the designs means that the aerodynamics and lift, downforce, drag etc have been very extensively modelled by the most expensive computers. But also that they probably won’t discuss what they have learned to risk giving away their secret sauce.Has anyone read any analysis/informed opinions about the hull/water surface interaction, in particular aerodynamics?
Travelling at 30-50kt the hull body can generate huge aerodynamic forces, any idea where the hull body is working along its hypothetical lift/drag curve? Do they tend to only minimise drag? Do they make use of some aerodynamically generated lift to complement the foils? Do they look for a specific aerodynamic interaction between the water surface and the hull (suction, ground effect, whatever) or they simply try and not touch the water?
Has anyone seen articles, notes, on the subject? The more technical the better![]()
Last post on this... But that's literally my point. The cup has always been changeable, as in able to be changed. The fact that it went through periods of relative stability in rules does not change the fact that at any point the holders could simply change the rules if they chose to. And often did.1- in post 34 you referred to what "The Americas cup has always been". If the Cup's past was relevant "in the context of a thread about the current cup" yesterday then the Cup's past is still relevant today. Nothing significant changed in the past day;
Absolutely - great result. Just a shame the conditions were in the all or nothing type winds for a hydrofoil. Very tricky for Britannia to avoid a drop off the foils which would have been disastrous.Nice to get a win on the board.
You are not alone in that.I don't think I breathed at all during the last leg.
