Absorbent matting
Andrew_Fanner
13 Mar 2002
ked into poverty by children
Having had a leaky gearbox pressure pipe (hopefully now fixed) and thereby put a couple of litres or so of ATF into the bilge I need a sensible source of absorbent matting. The stuff from Compass/other swindlery seems fairly dear and I want to put the stuff under both engines as well to get the bilges properly clean. Any suggestions where the matting might be available on the cheap? Tipping in a sack of cat litter isn't really an option as some of the areas are a bit inaccessible to get it out again.
rickp
10 Nov 2002
New Zealand
Andrew,
I've got some mats from Abzorboil and they are really good. They absorb the oil, but not water. You have to buy a bale unfortunately, works out around 72p a mat though, which is way cheaper than the Swindlery....
Rick
andyball
1 Jun 2001
i bought pads from Beals ( 0113 253 8888 )
pack of 50 1 litre oil-onlypads ( 20 x 16" ) for £12.90 + vat. work great They do general pads too, same price.
Beals are a car/workshop supplies place, & pretty much lowest price on anything they sell
Bajansailor
27 Dec 2004
Marine Surveyor in Barbados
I read a suggestion somewhere (might have been on one of these forums) to use baby nappies for mopping up oil and water under engines - tried one recently, and it works brilliantly!
And they are not expensive....
Gumpy
12 Dec 2006
A far corner of Little England
I use an Aquavac to remove spills then add it to the oil I have taken out of the engine and take it to the tip for disposal in their oil dump.
Aquavac also useful for removing other detritus in bilges.
Julian
