A4 stainless nuts: thread #12-24 UNC?
27 Aug 2005
wherever the voices tell me......
www.inox.ie
They supplied me with a few lengths of 3/4" AND 1" A4 UNC studding and the corresponding nuts for me to make a new set of keel bolts for my Centaur.
At the time (2009) local suppliers wanted 850 quid whilst the above supplier bought it in from the U.S. via Ireland and even with Irish vat (21%) i got everything for around 300 quid.
Just checked and they're still going, i think i dealt with the Birmingham branch for my order.
20 Jun 2007
Live in Kent, boat in Canary Islands
www.bavariayacht.info
prof pat pending
3 Jun 2013
Oxfordshire
There is, but that should do you :)
So when you measure the TPI does the angle of the threads match the gauge?
What sort of vernier do you have?
What is the OD of the thread?
Heckler
24 Feb 2003
It's a U.S thread standard so you could try looking at suppliers across the pond. Alternatively, BSW Whitworth is extremely similar.
Uh! If you are going to pronounce on things then make sure that you know what you are talking about.
unified threads took over from bsw and bsf here in the late 60s and early 70s then we went to metric. Unified thread stuff is still easily available HERE. Trying to use whitworth threads on unified thread stuff is just plain stupid! It doesn't fit! (There is one exception, 1/4" iirc) different thread angles, different tpi
Stu
Hypocacculus
15 Jun 2014
Planet Earth
Stu
I assumed that the OP had already tried and failed to get the stuff "HERE" - why else post to a forum and why are you so snappy about a suggestion that is still valid?
My suggestion of Whitworth is because the threads are very similar and the OP wasn't entirely certain what thread he had.
prof pat pending
3 Jun 2013
Oxfordshire
If you hold the thread up to the light, and sit the edge of the gauge on the centerline of the thread, you should get a good idea, although you are looking at 2 thread profiles which are very similar.
As for the thread dia, which side of 0.2 is it?
Use the wider section of the jaws to measure, don’t put too much pressure on the vernier :)
