A straight forward Where's this ?
fireball
15 Nov 2004
A straight forward Where\'s this ?
Taken yesterday (18 June)
Re: A straight forward Where\'s this ?
Newton Creek (again)? I mean, just outside it.
its gotta b iow and I also plum for newtown creek seen from the nnw mid afternoon
Not Newtown, there is a building on the left that is wrong - also rules out E Head as well I think. Skyline doesn't seem to fit for anywhere else on th IW.
It's too bl****n busy wherever it is. Please divulge the answer a.s.a.p so that people can avoid it. Do folks really go to such places by choice? /forums/images/graemlins/shocked.gif
Newton's quite a nice place to visit, ackcherly. /forums/images/graemlins/wink.gif /forums/images/graemlins/wink.gif /forums/images/graemlins/wink.gif
Although I've only been to Bembridge once, and a few years ago at that, it looks vaquely similar........
Ok - I'll put you out of your misery ... it was East Head ... taken from the Hayling end of the harbour ...
As a certain Ian will be able to verify ....
We didn't stop - not enough room! But then we did have a BBQ waiting for us....
Yep - East Head, fantastic feet up weekend in the sunshine and finally, for once, not upside down fixing something. Next weekend is the decant of cold weather gear and final prep.
Cheers
Ian
Speak for yerself. I spent the weekend upside down fixing things. Call by for a cool beer sometime!
Back in tomorrow.
tee hee, if this is what happens to the weather when you haul Amaya out then you can keep her out please. Fridge all fixed then?
Ian
Yes, thanks to Penguin Refrigeration. They took the cheapo system supplied by Pumpkin back and credited the cost against a Frigoboat system. Although it uses the same Danfoss compressor, it's much better built. Mind you, for 500 quid it should be!
In the process of fitting it, found a concealed space with a water purification filter which I never knew we had. It was due for replacement April 94 so guess previous owner never found it either!
Topside scratches fixed, topsides polished, old antifoul sanded fair, new antifoul, Maxprop serviced, renewed anodes, seacocks serviced and prop/shaft lanolinned. Mark is re-doing a botched gel repair to the bow (not me guv!) then back in tomorrow pm.
FWIW it was me sailing the RS Feva and towing the canoe. Don't think you recgnised me. We were anchored up at the shallow end and there was a bit more room up there.
Sounds good Tome, hope the water quality improves for you.
We are having Moondance lifted the day after the International Fleet Review. She will be scrubbed, antifouled, seacocks serviced, anode change etc. by a reputable chap in the marina who I have used before. However, I also asked for the topsides to be polished while she is out. He questioned my use of the word 'topsides'.
To me, it is the hull between the waterline and the gunwale. He said some people use the term for everything above the gunwale. WOuld be interested to know what you meant in your own post.
