aqua_sax
Allready posted. See Post 152
I know, but I restated it and provided a link as the source for the image I posted.
My speculation from the composite image is that I think I can see a sudden increase in vapour/gas emission from the aft starboard side of the saloon area and then a flame building inside immediately before the explosion. This may be consistent with damaged LiFePO4 batteries emitting gas (50%+ hydrogen) into the aft engine/battery space in sufficient quantity to (a) prevent ignition in that space (not enough oxygen left) and (b) push the battery gas mix into the accommodation where there was enough oxygen to create an explosive mix which was then ignited. But there are at least two big questions:
(a) what damaged the batteries enough to cause them to emit large quantities of flammable gas?
(b) what ignited the flammable gases?
As I have said before, but will repeat, I am actively considering installing a LiFePO4 house battery in my boat (ie waiting for any official report not really an option unless I shelve the project for now), and in that process I would be foolish to ignore an alleged lithium possibly LiFePO4, possibly not, battery fire/explosion. At the same time I am also aware that it is probably the only recorded (literally) example of an alleged spontaneous lithium (possibly LiFePO4) fire explosion, with the only available example I have found of an actual LiFePO4 battery fire here, only achieved by giving it the vampire stake through the heart treatment (not something I plan on doing), and then causing a spark the same way. Even after forcing a LifePO4 battery using external heat into quasi-thermal runaway, a LiFePO4 (LFP) battery failed to explode/ignite (photo from the paper I posted a while back):
The quasi-thermal runaway leading to large quantities of flammable gas production which is then ignited does seem at least plausible, but at the same time the evidence suggests it is extremely rare, in fact n=1 to date, and even that one is far from proven to be have LiFePO4 as the definite culprit. I have to balance one extremely rare event, about which the full facts are not known, against the fact that to date, there appear to have been no other confirmed spontaneous LiFePO4 battery fires/explosions on boats, despite thousands (tens of thousands? hundreds of thousands?) of installations.
My hunch - and that is all it is for now - is that the narrowboat explosion/fire had some other as yet unknown factor that caused the incident. This is loosely based on a sense that if LiFePO4 batteries do spontaneously cause fires and explosions, how come we haven't seen more actually happen?
