Its a Princess 67 ( and bl**dy enormous it is too! )![]()
Here she is up close and personal, more often than not crewed by just two, Mike and his well trained crew Mary (She's gonna kill me for saying that!). A beautiful boat indeed:
It was good to read Hurricane's p67 med delivery trip again - great adventure
Hurricane you wrote that after the biscay crossing you took on 3577 litres of fuel. The brochure stats on princess 67 say the capacity is 3400 ish. Were you right down to empty on the gauges? Must have been a bit apprehensive during the last 25nm...![]()
Has Hurricane managed to persuade Princess to fit the additional tank![]()
Ah thanks. The internet references I found (on a couple of examples on Yachtworld) must have been differnet model years (or wrong!). 4090 makes much more sense. Still, then needles must have been sphincter-tighteningly deep into the red zone if JW took on nearly 3600 litres!P67 2008 model year has tank capacity of 4090 litres.
Cheers
Jimmy
less then 500l left, never been that deep
Good for say 40 miles planing, and 140 at D speeds. Seems ok for me, but not to the std 20% factor. I guess it depends upon how well one knows the region, and where the diesel farms are?
Yup all true as a matter of maths. The issues become more things like
1. what angle/motion of boat will mean you cannot suck out the last bit of diesel;
2. inaccuracies in the gauges, such that you don't know you have that 500 litres, etc, and sight gauges don't help you right at the bottom of the tank, and so you're wondering (+scared) if you have only say 100litres and you're about to find out the answer to Q1
BTW I do not work slavishly to 20% on a larger boat. Hurricane will have had good data from the first 50% of that Biscay crossing with the option to turn left, so he will have been comfortable running tighter than 20% margin for the second half of that crossing I'd think
Iirc Hurricane went to some effort to gather accurate cruising fuel consumption stats before JW left the UK, to help with passage planning both down to St Carles, and then from SC to Valletta. That particular (18 hour) leg was I think 10 hours D with the rest P in order to safely extend JW's range to make the crossing from Mahon to Bizerte.
Cheers
Jimmy
Pah, obviously not a proper marine crew...And yes, the run from Mahon to Biserte was 10 hours at displacement - you may remember that everyone was very pleased to finally get onto the plane for the next 8 hours!!
