Laminar Flow
The Vikings had a means of measuring the elevation of the sun, but it wasn't calibrated - you could use it to check if you were on the latitude of a place you'd previously visited, but not measure the latitude. It was basically a rectangle of wood on a string; you held the end of the string at your nose, and one edge of the wood was on the horizon and the other on the relevant celestial body. The length of the string fixed the angle. If used with Polaris, it would be reasonably reliable.
[/QUOTE]
Yes, but it required you to revisit your destination at or near enough the same time of year as you made your previous stop over. This was not considered too much of a problem as going "viking" was done in "season" and chances were that declination at noon would have been close-ish.
Without knowing your declination even sighting Polaris will not be much help.
[/QUOTE]
