Matt341
HI All,
Im hoping to have some help on a few questions. We bought the Konsort a couple of months ago and a lot of things are different on it to our previous boat. I have gone through the boat and everything seems brilliant. However, we have stayed onboard a few times and the immediate thing we notice is battery power, she has no charger and with a lot of lights on the levels are dropping fast. So I have the following questions -
1) At the moment there are 2x120ah sealed batteries (not leisure), connected to a battery selector switch. We were told to turn on the main isolator and then turn switch to "both", when staying onboard this means that both batteries are equally drained. There is housing for upto 3 batteries so im wondering whether to replace battery 2 with an 85ah leisure battery, I have 2 brand new 85ah leisure batteries in the garage so wondering whether to connect these together and then connect as Battery 2 in replacement of the second 120ah which is not a leisure. This means switch 1 would operate the 120ah non leisure and switch 2 would operate the 2 leisure batteries which are joined together. Therefore switch 1 as starter and switch 2 as domestic. Thoughts on this please?
2) There is a 30watt solar panel fitted permanently on the coachroof and a regulator fitted inside the cabin, in the battery area the solar panel is connected to battery 1 using crocodile clips, this means battery 2 isnt getting charged. I feel this is a waste as when I arrive at the boat the regulator is always flashing indicating that the battery is full, yet when i switch to both the voltmeter drops from just under 14 to 12 something, im guessing its because battery 2 isnt as full as battery 1. If I was to change the batteries in the order of Point 1 then how would I go about charging the batteries using the solar panel both at the same time. Should I run another wire from the regulator to battery 2 or split the current wire going to battery 1.
3) I am currently using an automatic battery charger from halfords which I am putting on the batteries individually until they are full, however, by the spring I would like to fit something permanent which could charge all the batteries at once automatically. There seem to be quite a few around, what would you suggest as the most reliable and the best suited for the battery sizes?
I hope this all makes sense.
I look forward to reading your suggestions.
Many Thanks
Ian
Many Thanks
Ian
