differentroads
A tip on cutting rigging wire. Get a block of hardwood about 10cm x 5cm x5cm. Cut a slot lengthways to about 2/3 the way down to take a hacksaw blade - a circular saw blade thickness is about right. Drill holes through it crossways to take your rigging size(s). Buy plenty of hacksaw blades. Makes a much cleaner cut than holding the rigging in a vice and is much easier.
I've also considered turning the holes for the rigging into slots. The block would then help me cut the rigging away faster if the mast came down at sea. But its better to inspect the rigging regularly and closely to try and avoid that. Which I'm due to do this year
