coopec
N/A
May be something useful here?
http://www.mademan.com/mm/5-best-single-handed-yachts-ocean.html
OK exactly what form of motorised tying-up-alongside aide do you have? I was fortunate to cadge a lift last year from Dom of this parish. I'm fully aware of how a properly equiped 50'er can be handled well by a single person at sea. I'm no longer a spring chicken and it was rather a long way down from the deck to the pontoon. Nothing I said implied it was wrong to accept assistance form someone ashore, if they were about. If I get over this year, we can talk about what can go wrong if you do, though.
As I said , each to their own, however, I think if you believe that the loss of performance caused by an in mast reefing system is small, then I think your missing trick or two.
Yes, it lets you change the sail area, but using the sail controls you can change the power of the main, outhaul, mast bend, leach tension, it's really easy to control a fractional rig.
With in mast reefing you normally lose the roach, battens and you can't bend the mast, because the reefing system will jam, which severely limits your control over the sail shape. As you roll tha sail away, you take out the forward part of the foil shape of the sail, destroying any shape the sailmaker manage to cut into it. You also have the possibility of the reefing system jamming.
I see little difference in the difficulty in controlling either option, but a significant performance advantage, in a conventional slab reefing fractional rig.
I know from sailing against similar sized yachts with in mast furling that my Southerly is about 15% faster to windward, i.e. about 1.5miles in a typical 10 mile beat. in my book that's significant, and she's no light weight flyer, over 16 tons on liftout at the end of last season.
However, I do agree with you on most of your other points, a small self tacking headsail, mines about 95%, which eliminates the need for winching when tacking, and allows a much closer sheeting angle. The sail areas on the Southerly 46RS are 58.98 m^2 for the main and 44.9 m^2 for the foresail, and if I'm seriously taking it easy, the boat will sail to windward very well under jib alone.
Finger pontoons in marinas are frequently shorter than the boats being berthed and using a single spring is Not an option, especially when there is no "cleat" on the end of the pontoon. You can't always find a vacant "tee".
My 'faves' are the little sinky fingers with only a loop of aluminium on the end to pass a rope through... no cleat... near impossible to do a decent arrival on if alone or with inexperienced crew - even assuming you can balance on the thing when you hop onto it... Cherbourg used to have them, might still?
At home berth we prefer stern to as the 389 has a full width bathing platform that is pontoon height when lowered. Great for getting on and off. When visiting other places it varies. The 389 is quite a wide boat at the stern with twin wheels and throttle / bow thruster controls on starboard side. Due to this I prefer to put her starboard to as i can keep a close eye on the pontoon. Often not a lot of space if two wide ass boats. 240v hook up is also right at stern so easier if stern to. Conditions also play a part. She blows off very quickly and wants to point downwind in the slightest breeze. Each entry to a berth is a compromise based on conditions, space, side to etc. I have no hard and fast rule about stern or bow to as doing so can result in gelcoat repairs.Interestingly, though, there does not seem to be any real consensus as to whether to moor bows-to or stern-to. I would be interested to know the pros and cons of each.
1. I have got used to the space and creature comforts of our 42' motor boat and so I would ideally like to get something with a similar internal volume. A Marlow Legend 40 seems to have a similar layout, whilst the Marlow Legend 37 comes close but sacrifices the second head and some aft cabin space. However, would boats of this size be too much of a handful to regularly single-hand - both in sailing terms and when backing into a tight marina berth?
3. I have had masthead rig and fractional rig boats but have only ever had slab-reefing mains with furling head sails and, even then, I have not relied on a single furling head sail - rather, I had a selection of head sails and simply chose the one most appropriate to the conditions, just using the furling system to temporarily stow the sail. Most modern boats seem to have relatively small furling head sails and so I take it that, in a blow, they will only require a few turns of the furling gear and so should still keep a reasonable shape and perform adequately. However, how do the relatively larger main sails perform with in-mast furling? Despite there being some loss of sail area, this looks very convenient for single-handed sailing but does the sail keep any reasonable shape / performance once more than a turn or two is put in the furling gear?
4. Lastly, many modern boats seem to come fitted with sail drive units, rather than conventional shafts. I was hoping to get away from the complications and expense of stern-drive maintenance but the sail drive units look like just another unnecessarily complicated answer to a simple question. How reliable are these units and what is the likely annual servicing cost for the drive and motor, assuming that I were to use a franchised dealer?
Thank you again to everybody who has contributed to this thread - your insight and very detailed replies have been very much appreciated! Thank you also to 'Tranona' for meeting me in Poole and showing me around his very lovely new Bavaria!
I have spent a few days looking around at what is available and I think that I may have to accept that lifting or twin keel boats are just too few and far between to exclude fin keel boats from my shortlist. Having said that, there are 'deep fins' and 'shallow fins' available and I would therefore be interested to know how they compare. Anecdotally, I understand that >2.0m draft is getting a bit limiting for Cobbs Quay...
