kingsebi
A friend that had a 20m ferro cement boat that he sailed from South Africa to the Caribbean told me that he infused the hull with Coca Cola when it took on water and started to rust. He said that solved the problem.
We ( Yachtsnet ) brokered the sale of another professionally built Hartley RORC 39 some years back: it had done four transatlantic circuits in the previous ownership, and surveyed well. Not a slow boat at all. The new owner later reported how much he liked the boat.There’s a very nice ferro boat here: Hartley RORC 39 For Sale, 11.90m, 1979
I’ve been shown around her and this boat was built and fitted out to a very high standard. At that price, it’s a steal for someone.
And there's the rub! Done right includes having cement with the right additives, and determining whether or not the right additives are present is not trivial, and would require sampling of the cement, assuming it's possible - I am not expert in cement mineralogy!We ( Yachtsnet ) brokered the sale of another professionally built Hartley RORC 39 some years back: it had done four transatlantic circuits in the previous ownership, and surveyed well. Not a slow boat at all. The new owner later reported how much he liked the boat.
Everyone has seen horrible bad-amateur-built ferro boats - but there are good ones both amateur and pro built. Done right, ferro has a lot going for it.
There are modern additives that can make cement self healing - if a crack forms, new minerals crystallise to heal the crack. But I'm pretty sure they weren't available in the heyday of ferro construction, and I think they aren't in widespread use even now; I've come across the concept in scientific papers relating to making buildings more resilient.
They did, but the reason it was self-healing was only recently discovered from new excavations in Pompeii that uncovered a working building site. Apparently, they mixed the cement hot, but I forget all the details; it was only published in the last year or so, though, so it should be findable. The work I am recalling worked cold. But the principle is the same - the chemistry and mineralogy promote recrystallisation in cracks.Didn't the Romans have that sussed a couple of thousand years ago? Self-healing waterproof concrete using volcanic ash if I remember correctly.
That film of ferro building on Fambridge brought back memories. I remember those days and many of the characters portrayed.
Do you also remember Bill at Tollesbury ?That film of ferro building on Fambridge brought back memories. I remember those days and many of the characters portrayed.
The large yacht I think was called Juanita. She was winched on greased skids as shown up through the pub car park and down the road., took several days I think, and the crane was never the same again.
I remember that someone posted on it on these fora. Plasticizers and additives to control setting time come to mind.Would be interesting if there is anyone here that knows the mix that was used in professionally rendered ferro boats. Compared with timber/plywood. 60 years is not a bad design life. I imagine people would be happy if they thought that they would last that long.
Self healing mortar never lost - traditional lime mortar, used for all brick and stone work right through until recently,
Fine lime free washed sand and sulphate resisting cement mixed at 1:1 ratio . Once the hull is plastered it needs continually spraying with water for 1-3 months while curing.Would be interesting if there is anyone here that knows the mix that was used in professionally rendered ferro boats.
The oldest known ferro boat was built in 1848 in france. It is a rowing boat built using mesh and cement. It still survives today in a museum.. The Maritime Museum at Bremerhaven has what they label as the oldest concrete boat;
Spot on . One month is the minimum but 3 months makes it stronger reaching full strength at around 10 years.- can see that the 3 month curing time sprayed with water would have been key to crack control
