[70521]
I'd still be concern about the weight then, but in a different wayUnless you're building a steamroller.
I have had efoy 210 fuel cells on my last two boats and think they are a great bit of kit. In fact everyone that has seen my installations and consequently followed suit all now thinks the same. You install them, switch them on and forget about battery charging. The system has high and low watermark voltages and comes on and off as and when required to do so, it is entirely transparent and pretty much a silent operation. In my last installation the waste water was put into a bottle and I could easily measure the amount of fuel I was using.
It's also worth mentioning that the manufacturer are easy to deal with and make updating and managing the product a breeze.
Interesting, more information would be useful. e.g. Type of use (living on boat or just keeping batteries topped up on mooring etc.). How did cost compare with solar when you examined that option?
EFOY wouldn't be viable for me due to amount of energy needed, abundance of sunshine. Hydro doesn't work either as I'm not always on the move but would generate plenty on an Atlantic crossing. However, I will eventually return to UK and might re-evaluate EFOY. Last time I checked solar panels were hugely more cost effective, even in Scottish waters. I didn't think much had changed with EFOY technology in last 5 years.
My use case is racing, specifically single handed and two handed offshore races where the pilot is used a fair bit. With instruments and pilot my consumption ticks over between 5 to 8 amps. Solar not really viable for racing. I owned a watt and sea for a while but found that putting it in water at speed was hard work and drag from it was over tenth of a knot.
Specific cost comparison not really done given lack of workable options for an 11m race boat. However given cost of campaigning a boat for a season it's negligible and it makes a nice change just to have a bit of kit that works.
Looked at a boat today that was for sale that had one. I'd never heard of them before but a search brought me to this post. Initial cost is expensive for such a low output. I know they burn fuel and output electricity but how exactly do they work?
Got it now thanks. Fuel at £40 a gallon , wow!
List price of fuel is £96 for 20 litres. Not sure how you get to £40 per gallon?
Rough rule of thumb calculation puts that at £20 per gallon, which is still quite steep.
You're forgetting that the unit itself has a limited lifetime - the membranes last about 5 years. So you've got to add the write-off cost of the equipment to the cost of running it.I guess if you only look at that aspect of it then on the face of it it's pricey. However if your racing and don't want to run your engine in neutral for hours at a time, don't want to work your way through alternator belts, don't want to listen to the engine while off watch and do want something that you can just turn on and forget about then it's value becomes more than pounds per gallon.
Pretty much everything we add to our yachts has a limited lifetime, sails being one great (expensive) example.
If we were to only ever consider the value of a component based purely on its cost and subsequent run rate we'd very quickly suck all the fun out of sailing. I appreciate fully that one person's value for money is another's expensive however my point was that the value of something is as much about its ease of use and what it ultimately facilitates as it is about what it cost.
Most things that cost as much as the eFoy cells have a considerably longer life-time, and the life-time can be extended by appropriate maintenance and/or part replacement. Not all of us replace sails on a regular basis, and many of us expect equipment to last for decades, not years. Most of the equipment on my yacht is as old as the boat; the exceptions are where I have upgraded to gain new capabilities.
It would be interesting to have a sample of fuel sent for analysis.
IIRC, a sales rep told me it is Methanol, but very pure.
My old mate Mario was boss of a Phamasutical Chemical Company nearby. He would fix me up with a 205 litre drum of the best it was possible to buy every season for use in my Track Racing bikes. He used it as a re-agent in producing his products.
He always asked me " Did your bike go better on my stuff-its the purest you can get! "
When he sent me the invoice it was about £1.40 per litre, so multiply by 4.4 equals£6.16 per gallon.
As it is not used for propulsion, but electricy generating, the fuel tax could be claimed back.
I cant imagine-and nor could he last time I spoke to him about it-what they do to get it more purified than the Methanol used in the production of industrial quantities of pharmasutical drug base.
Just saying.......................
