vas
just had a good look at a AQUAPRO SMR 1101 ali hulled rib which is 3.48m long (11ft for you up north, I hope your PM wont move you back to imperial after the elections
Although it's a PVC and a 2007 production, it's one of the NZ built ones (2008 onwards I'm told they moved the production to China...) and it was in a surprising good condition, well impressed.
However, I was more impressed and scared on how big this thing was, so went straight back to MiToS and measured the bathing platform. Well, I thought it was around 4m but that's the max width of the boat at deck level
So platform is:
3.70m at the transom
3.50m at the back...
and 1.2 or 1.3m long
Considering the steps to the aft deck and the placement of the swim ladder, things are rather too tight. Tighter than the pics above by Nick and CharlieAlpha
However my friend with the P45 has a 3.6m tender and he thinks I should go ahead and buy it as a 3.1 is going to be too small.
I feel that if I shift the tender towards the stbrd side and the "nose" is say 20cm proud of the platform (but still within the 4m width of the hull) I'll have just enough space to jump and come up from the water without too much trouble.
Due to the passerelle ram, tender will have to be further aft with the keel around 30-40cm from the aft end of the platform. This way I'm thinking I may be better off turning the tender around with the engine at stbrd and the bow over the port side and aft of the swim ladder. Definitely not a case of 3-4 kids fooling around by the steps as they do now, but most likely with a decent tender it's always going to be in the water unlike this disaster Valiant that was falling apart and leaking from the tube to transom... (took me a few days to figure it out)
So, about to check a few more tenders in Athens and another AQUAPRO SMR1101 with hypalon tubes on Saturday. If all turns nice and I get the approval of the forum experts, I'll probably get there and pick it up midweek.
BTW, one thing I really like on the ali hulled tenders is the two massive (ok relatively!) reinforcements on the hull to transom that you can use to cantilever a nice custom box seat without messing with grp/sanders/glues and all that crap. Then I could built a custom steering wheel extension that can tilt down and out of the way and I'm done!
So looking forward to reasons I shouldn't do it
cheers
V.
So platform is:
cheers
V.
