Channel Sailor
Today I discovered the engine mounts on my 1995 Jeanneau yacht are incorrectly installed. The front mounts are 75 starboard and 100 Port. Should be both 100 on the front. This means I have a softer mount on the starboard front. Similarly the rear mounts were, until today, 75 and 100 which was also incorrect as they should be both 75. The engine does suffer from a strange resonance though most of the mid range speeds, a small amount of shaft wobble and it does wobble somewhat at tick over enough to rattle the mast and a few interior fittings. Hence why I swapped the aft two for new ones (matching 75s) to see if it would solve the problem.
Unfortunately due to tides and Christmas I cannot get out for a sea trial for a couple of weeks, so I am wondering if this was an error in the factory by the installers or they have been set like this solve a boat specific resonance problem. Has anyone had reason to have non standard or non matching mounts Port and and Starboard and why?
