@Poey50 How did you get to a 225Amp rating? What is your BMS / relay rating and cable size?
I'll keep on reading till the w/e and order on Monday. Then I guess I'll be back in January with more news![]()
sorry, you are correct but I should explain that all my victron kit are connected to a raspberry pi running VenusOS. This means that the MPPT port is already "occupied" with a VE.Direct connection to the rpi and cannot be used by Electrodacus to instruct the mppt to turn off and on. So only way to do it is for Elecrtodacus to communicate intelligently with the VenusOS "master" device and then this will instruct the MPPT to do as it should.Quote:Electrodacus is build in low volume in Canada by the guy designing it, he's v.knowledgeable but v.focused on what he wants and not really flexible on others' needs. He's somewhere in the vast plains of Canada with a large array of solar keeping his house running on solar alone (or something like that...) No reason to connect with victrons as he claims that with lifepo4 you don't need MPPT controllers and he's developed his own uber cheap switching thing for his panels (largely useless for us boaters I should add - his moto is why buy an expensive mppt controller, stick a few more panels on your land). BTW, there's a indiegogo produced retake of this board in Romania so customs/tax will be zero for us in EU. Too many complains for delays in delivering the goods though so will contact the guys and thread carefully - plain board only 83euro (includes tiny screen and touch control for it) Some one is working on connecting to Victron, not done yet.End quote
Electrodacus works well with Victron MPPT. It can control any Victron MPPT and will also connect easily for control of virtually any Victron product - inverters, inverter/chargers. battery protect, chargers, etc.
I agree Dacian's PWM controllers are not a good match for a boat.
@Poey50 read (again) the start of this now epic thread but i could not find what you large cable sizes are.
Could you share? 25, 30, 50mm2? Thanks.
@Poey50 i think you might have covered this already ~ how are you dealing with float charging between weekend usage? And also by extension winter downtime?
Do you have solar and/or a bilge pump connected? I seem to recal a BMV-7xx shunt that will draw something along with the BMS.
Thanks.
Do you have an absorption time set on the victron charger? Can you share your settings?
At that voltage i assume your not hitting balance settings. Is that a concern?
Rule of thumb is that anything below 13.4 volts doesn't bring LFP to full charge. Anything above 13.4 volts will eventually bring LFP to 100%
