pvb
Unless my toilet was fused near source and then an other cable run to the main panel then to the battery so sorry your talking rubbish your using extreme examples to prove a useless point, on a 13 metre boat how is it possible to have a toilet 12 metres from a power source,
Quite easily, boat wiring usually doesn't go in straight lines.
the toilet is run to a separate fused panel 3 feet away 30 AMP CABLE and then from the fuse panel back to the main fused master (30 AMP CABLE) panel were it is feed from 300 amp core wire from the master battery , as the run is more than 6 feet from first fuse to master panel it is fused again to protect the run , all large runs need 2 fuses to protect either end
More misconceptions, you don't need fuses at each end, only at the battery end. Additional fuses serve no purpose and are a source of potential failure.
9 feet =2,74 metres on a 24 volt system like I said earlier you don't need to deal in fractions , so the voltage drop in negligible so please use facts not rumbles from your belly and pie in the sky thoughts
No, the voltage drop isn't negligible. Jabsco, for example, would recommend at least 4mm² cable for that run. I'm only a simple engineer, so I'm used to dealing in facts.
